Rack & Pinon installed turns more to the right than left
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
i have a 2000 trans am just installed a rem. rack and pinon from advance auto parts i have not had the car aligned yet. when i set the steering wheel in the middle i can only get 3/4 turn to the left till i hit the lock and can get 1 1/2 turn to the right till i hit the lock. if i turn from lock to lock i can get a little over 2 turns. i compared the new rack with the old one before i returned the core and the length is the same and the angle of input shaft is the same clears my header just fine like the old unit. so will just a alignment get it to turn the same from center to left or right or do i need to set the steering wheel till i get it to turn from center the same distance on both side and then pull the steering wheel off and recenter it and tighten the nut down any help is appreciated.
thanks
thanks
Try this with the new rack.
Center new rack and pinion. Turn rack all the way to one side and place that side against a stationary object. Making sure the housing does not move. Turn the rack back all the way to the other side. Measure the gap between the stationary object and the end of the rack. Turn the rack back half the distance. We suggest you make a mark on the pinion and the housing, in case the rack moves during installation.
- Connect new steering shaft to the steering column
Fluid will probably come out. There is a cap at the bottom, take it off, there are two snap rings i think, one on top one on bottom, seal on top, nut on bottom, take all that **** off, tap the pinion up with a hammer, turn it and push it back in.
There might be some small piece i am forgetting but thats the gist of it. Oh and you should measure and mark where the pinion is so you have some kind of direction on where to go. There is a lock or dowel somewhere that needs to come out for the pinion to come out too. Sorry i dont remember perfectly.
P.S. this is not the best advice i have ever given, but i didnt have the option of returning the rack so i just kinda threw **** at the wall to see what would stick.
Thank you i will give it try this weekend and hope for the best i wish i can return it but its been to long at this point ive had the rack uninstalled for a year and already threw away the receipt oh well. just to clarify you are talking about the input shaft where the steering linkage attaches, that plastic cap around the input shaft pops off and then ill see the snap rings and seal?
I think there is a small snap-ring in there once you remove the cap. There is also a snap ring on top where the steering column attaches.
i really wish i could be more precise with the info but i dont remember everything exactly. if you google rebuilding steering racks they are all pretty much the same design-wise or close. And you only have to worry about removing the pinion, so you're really only dealing with 5 or 6 small parts all together.
