Torque Arm Mount??
Old Jan 23, 2012 | 07:48 AM
2camaros6702's Avatar
Default Torque Arm Mount??
I am running low 10's in the 1/4 with mid to high 1.4 60' times and still have my torque arm mounted to the trans tail shaft and my question is should I go ahead and get a T/A relocation mount? My next question is will it help my suspension or just keep things from braking? I have a broke trans now and am getting it fixed so I don’t want the added cost but if it will help I may go ahead and get one.
Old Jan 23, 2012 | 07:58 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
It is always going to be good thing when you get the torque arm off the torque arm off the tailshaft housing of the transmission. Not only will it keep you from breaking tailshaft housing but it will also allow to adjust the instant center of the car to help out launching the car. Give me a call and I will take care of you on it Greg.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 23, 2012 | 08:13 AM
UMI Sales's Avatar
Torque arm relocation is good insurance and prevents the dreaded destroyed tailhousing.
Plus, it gets rid of the rubber biscuit and replaces it with poly. And as mentioned, you can raise your torque arm a bit to improve IC location. You have to be careful though as driveline angle (pinion angle) will start to creep closer to zero with a stock torque arm...
ramey
Old Jan 23, 2012 | 08:37 AM
I have an adjustable BMR TA on the car now.
