Need softer suspension
When I bought my Z, the previous owner had it set up for autox. It's got an aftermarket torque arm, lcas, subframes, brakes, revalved bilsteins in the front and stock bilsteins in the back with hypercoils all the way around. Stock bumpstops are shot. Now that I own it, it serves a different purpose. Its a pretty friday drive to work, cruise in, and once a year drag strip car. The suspension is BRUTAL, near bone jarring. Obviously I still want it to handle good, but I'm more concerned with ride quality. Is there a better spring for my needs? How about a set of stock ls1 or v6 springs with a half a coil cut out? I still want it lowered, but wouldn't mind gaining a little ride height back. I think currently it's around 1 1/2" drop, and I'd like to have 3/4" or 1" drop from stock. Whatcha think? Thanks!
SLP Springs would get you that kind of drop. The LCA's, your best bet is to find some stock ones with regular rubber bushings in them. Get the front Bilstein's revalved to stock specs for their shock ($65 per shock to do). Run jeep bump stops in back with out the aluminum spacer.
LS1Tech Premium Sponsor
While I never condone altering a factory spring, it will allow you to get the ride height you may be looking for. Keep in mind, cutting a coil from your spring will raise the spring rate. I'm not sure how much it will impact the ride quality because I have never done it, but from what I'm told, it isn't "too bad", which is a description I find too ambiguous. The SLP Eibach springs will lower the car approximately 1-inch.
- Kevin
Thanks for the reply. As with any used car, I'm not sure of anything except the parts I've put on it. I'll check the shocks when I pull it apart in a few weeks. I'm leaning toward cutting stock springs about 1/2 a coil only because I have a set already that came off the last one I owned. These are taking up space. If I don't like it, I'll probably look at a set of SLP. It's got to be better than what I've got now.
LS1TECH Sponsor
Ahhh, If I may.... If you have what you think you have, the SLP's won't help unless the rear shocks have just given up (which is possible as if the stuff is what you think it's gotta be at least 5-7 years old, and the rear shocks where never ideal for those springs anyway.
In short, Hypercoils are best run on Koni's. If you back the springs down (they use a really stiff rear rate), and put some bumpstops on then Bilstein's will be ok, but never ideal for lowering springs.
Frankly a spring change would help, get the rear rates down, and shocks that are a better match to the springs. Again, Koni's are the ideal, but as you come down to something like my springs, new fresh Bilstein's can work too.
__________________
Thanks for the replys, I'm gonna try a the set of factory springs with bumpstops and I'll report back in a month or two. It may be that long before I get it back on the road.....gotta put cats back on it and figure out why my twin disc is slipping
