Subframe connectors
I have the correct subframe connectors- which are a true frame connector and not a rail that prevents damage to your rocker pinch weld area, and these will not interfere with your exhaust.
I also have the rear anti-roll bar that is 20 pounds lighter and is the quickest responding to torque input.
I also have the best prices and the track experience to help you with your setup and get all your power to the ground.
Give me a call... I have a few other ideas that may help you as well.
