Lowering Req. Adjustable A-Arms?
The basic question is actually very simple:
If I'm lowering my car (1.4-1.6" with the Eibach Sportline springs), do I need to have adjustable A-arms in front to correct the alignment back to stock? If so, how adjustable? Do both upper and lower arms need to be adjustable? Do both bushings need adjustments on each arm (ie, some lower arms feature adjustment at only one bushing)? Yes, I plan on buying an adjustable panhard bar to re-center the rear. I would like to avoid the novice (ricer) mistake of excessive tire wear and decreased handling by doing the job properly and safely. If you have expertise in this area, it would also help me to know your background in your reply. Thank you in advance for your help!
If you want to save time, no need to read on from here. If you're interested in the details, here are my plans: I have a 1998 Trans Am that I previously swapped to complete WS6 parts off two wrecked cars (one wrecked in back, used the front parts, and one wrecked in front I sourced the rear, one car with 15K the other with 20K mi) when I bought it about 8 years ago. It had 100K on it then and I'm at 181K now and it will be time again soon to swap suspension. I plan on going to 19" wheels, 275/30R19 tires (possibly 285 on rears or spacers). I don't drag race at all and I don't really autocross, although I do some pretty aggressive canyon carving from time-to-time. My goal is much improved stance/appearance, sharper handling, and less bounciness (through chassis & armature stiffness plus better shocks). I've driven a WS6 with the HD Bilsteins, subframe connectors, and what were likely Eibach Sportline springs and felt it was very close to what I wanted. Here is what I have planned for now:
Bilstein HD Shocks
Eibach Sportline Springs
Subframe Connectors: UMI Tubular 3-Pt. Bolt In
A-Arms: BMR Upper & Lower A-Arms [AAP004]
Tierod Bumpsteer Kit: Spohn Performance Bump Steer Kit [BS-4
Strut tower Brace: UMI Strut Tower Brace [2005]
Antirollbar Fr. Endlinks: Prothane Swaybar End Links [19-409-BL]
Antirollbar Fr. Bushings: Prothane Swaybar Bushing Kit (32mm [7-1137-BL]
Antirollbar Rear: UMI Performance Solid 22mm Sway Bar [2113]
Control Arms Rear: J&M Products Street 3 Piece Poly-Ball Bushing [23851]
Control Arm Relocation Brackets: RPM Speed LCA Relocation Brackets (Bolt On [18832]
Adj. Panhard Bar: RPM Speed On Car Adjustable Panhard Bar [23790]
Bump Stops Rear: http://www.stranoparts.com/partdetai...D=19&ModelID=8
Fender Roller 5 day Rental [FNDR-RLR]
Funny story... I had not heard of the heater hose mod before, but I kind of did the same thing on my car years ago when I put the WS6 springs in. I was actually hoping for less noise transmission into the car, so I wrapped both ends of the springs in heater hose and left the upper rear isolators in place. I'm assuming this probably added another 0.5" or so to the rear, exacerbating the 4x4 look I so despise.
Anyway, my question still stands. Will I be able to properly align the front end after lowering (I guess 1.2" now) using these A-Arms?
First, "WS6 springs" are the same springs as the stock TransAm/Camaro gets, they are 114lbs/in rear, which is a pretty low rate. The added harshness you could have felt was from shitty stock decarbon shocks with their higher compression (shitty handling and ride).
Next if you want to corner crave sticking with 17s would be a much better idea (less weight for starters, but you will definitely get a better ride out of it).
"bouncyness" is all from shocks, nothing else. You get a good shock in there and there will be no bounce, you get one that can't control the spring and it will bounce.
As for the list:
The Bilstiens are a good shock for stock springs, but not really for lowering springs with less travel and more rate for the shock to control, I would look into some Koni SAs (4/3 setup if you want to save some money, check out stranoparts)
Seems you have done a little searching with your above post, sportlines are the worst of the worst, unless you don't care about ride or handling ditch them.
Don't need any of this. If you have some extra money laying around you can throw some SFC's on there, but don't expect to be able to tell a difference. Save that money and put it toward better shocks, will be a WAY better investment.
JD_AMG, thanks again for all your advice and taking the time to compose your reply. Hopefully I don't come off too defensive about my choices, it's just some friendly debate
, and certainly don't take anything to mean I am not appreciative of your advice, because I am. I have done a fair amount of research including driving f-bodies with various parts listed as well as reading what is available online. Unfortunately, when it comes to the internet, you can't always believe what you read, be that from sellers or customers. Generally, when it comes to customers, unless a part is really bad, people will succumb to a bit of placebo effect, especially after spending money on the parts. I've also been active in a 4th gen mailing list for 8 years now, and this includes a lot of people who have experience racing and who have been through multiple setups with long term experience.
I trust guys like Sam Strano because of the vast experience, and proven results (multiple national SCCA auto-x titles) that no other suspension vendor can come close to.
Some definitely got the standard springs though.
So many people object to the sportlines because they lower you so much you are sitting on the bumpstops, and then they don't have enough rate to compensate for the drop.
The "roll" you feel may be your shitty shocks. Check out what the auto-x/road racers use (35/22 or 32/19).
http://tech.firebirdv6.com/general.html
"WS6 Performance Package suspension components include a 32/19 mm front/rear sway bar combination in lieu of the normal FE2 suspension 30/19 mm. The front spring rate increased from 51 N/mm on a normal V8 Formula/Trans Am to 63 for the WS6. Rear spring stiffness on the WS6 suspension carries a variable rate of 23 to 30 N/mm compared to 19.9 on a normal V8 Formula/Trans Am. This Package also included different shock valving, 1LE transmission mount, 1LE panhard rod, Ram Air hood, and 275/40ZR17 tires."
couple comparisons here: https://ls1tech.com/forums/suspensio...gx-02-ws6.html
If you are going for handling, then I would say yes hands down they are worth the extra money.
Those A-arm are for getting a more extreme alignment.
(I have to admit that when I first started reading that thread I got the comments on KYB mixed up with Koni since they both start with "K"...
) I have a friend that put KYB adjustable shocks in his Prelude Type SH and now I know why he was unimpressed.Those A-arm are for getting a more extreme alignment.
If you really want to try go ahead, but have money set aside for a 35mm front bar, I bet you'll want it afterward...
I'm starting to think about just popping the 1LE rubber bushings into the stock rear LCAs. I don't think polyurethane binding would be as much of an issue with the front though, as double wishbone setups don't have to twist the way struts or live axle parts do.
Again, thanks to JD_AMG for your advice and to bwkmaro for chiming in.
