Need help with set up......
Package 1: Strano Springs, Koni yellows... $1296
Package 2: BMR springs, Koni yellows, BMR sways.... $1299
Package 3: SLP Bilsteins and SLP Eibach springs, UMI sways... $930
I don't know what to get.
Out of those I would go with package 1, but preferably package 4 that I posted above.
What about this one? http://www.stranoparts.com/partdetai...D=92&ModelID=8
What is the 4/3 and 4/4?
The 3rd gen rear have less adjustments and require you to take the shock off the car to adjust while the 4th gen rear are on car adjustable. As far as dampening differences thats a question for Sam to answer.
As for the sway bars, yes they will make a huge difference in handling and have little to no effect to ride quality (really the front bar doesn't effect ride while the rear bar will a little).
I had package one, it's very good. I would not recommend the second, as the rear bar is too big. The last one would be a compromise set up that should give you a slightly better ride than the others, but not the handling.
So this one would be what I am looking for?
I forgot to mention I have a Strange 9" so I don't know if that makes a difference or not........
Our springs are nothing but high quality pieces. We have a lifetime warranty against defects and sag - we still haven't had a set come back. There was even a potential warranty claim on LS1tech.com that turned out to not even be our springs but we made the offer to take them back. Best of all, they're always in stock and don't need to be pre-ordered.
As for the bars, there is no set of bars perfect for all setups and it's all subjective. It's not just diameter, it's leverage arm length, roll center, wall diameter, and a lot of other variables that make up actually bar stiffness. From our testing on several cars in a variety of driving conditions, we've found our bars to provide a great balance for many shock and spring combinations, and greatly reduce body roll. We're confident you'll greatly appreciate the bars, springs, and any of these three shock options we can provide you - and I'm sure the price will be great too.
Please let me know if I can help you with anything or if you have any questions about our products or about your combination/goals.
- Kevin
