Abs inop,abs,tcs light?
Ok so im getting ready to order a sjm abs delete and the guy i talked to said these lights would stay on after i did the delete, can i just simply remove the bulbs so these lights won't be driving me crazy? Or am i gonna have to just deal with it?
i just did the abs delete and my abs inop, brake,tcs off and service engine light all came in. i had to do some welding on the exhaust so i unhooked battery and the tcs off light is gone. when i hit the button nothing at all happens. is this normal also?
I am told that it is the back side of the EBCM (electronic brake control module) that is the issue. I am having the same problem so the next step would be to replace it to keep these options available. It is a 4 channel module with traction control. The 3 channel does not have traction control and they are not interchangeable. I just found one so that is what I'm doing. Let me know what you did to fix the issue. Thanks
