Poorman suspension set up as far as springs/shocks
Is there a write up on here about using a poormans method for shocks and springs? My buddy says that there is a write up somewhere sayin that u can use iroc shocks and springs and use them on a 99 fbody and that they will make a good strip/ track shock
LS1TECH Sponsor
HUH? The fronts are completely different, they won't even work. The rear springs are pretty much what you have (actually stiffer, which isn't what you want) with just a different type of crappy rear shock.
__________________
poor mans set up is
cut 1 coil on all springs, and heater hose mod in the rear...
however,if you do it, plan on it being a temp.set up
i can get a better pic tomorrow... however, the car hasnt fully settled yet, itll be a little lower
![](https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/426736_196941970407132_100002739921446_252058_1323956626_n.jpg)
however, just a fair warning, with my car, the rear sat lower than the front after doing the heater hose mod...
so i left the heater hose on the spring, and even put the rubber isolators on top of that... so now it has a nice squat to it
however, i plan on going to a set of sams springs with slp shocks soonish
