Has anyone built wood block jacks aka "cribbing blocks"
Old 03-17-2012, 10:46 PM
01 ss vert's Avatar
I finally got around to taking pics for you. If you got any questions, just ask.
About half way through on my rollbar install. Should finish it tomorrow.
Old 03-17-2012, 11:29 PM
mikh338's Avatar
ahh so you did yours a little bit different then the OP posted, but it works!!
Old 03-18-2012, 12:03 AM
WS6Wes's Avatar
Cool appreciate the pics. I might just end up doing this and stack wood instead of assembling it all together. I can see why you said to go alittle longer then 12'' that 3rd picture looks like it's cutting it pretty close lol.
Old 03-18-2012, 11:19 AM
01 ss vert's Avatar
I didn't fasten them together for a few reasons:
1.) I would have to spend a lot of time to fasten them all together and not expose any hardware.
2.) Lifting a corner of the car that high at once would be unsafe. I went around and did 1-2 boards at a time. I could see the wheels moving some as I would lift one corner at a time, so for safety I only did 2-3" at a time.
3.) Storage space.
Note, the front onces are a ramp of two pieces at the bottome - this is the only way for me to get a jack under the car sicne it sits so low. I use these all the time. To get the car this high, I added 3 additional pieces to the front, 5 for the rears - which is what I just added this past month. I keep one of these ramps in the trunk at all times in case of a flat. Also note - all the jackstands you see are not under load - only the wood it. It works and between buying the wood, driving home, and jacking up the car, I got under 90 minutes in the whole thing.
Old 03-23-2012, 09:24 PM
mikh338's Avatar
3.) Storage space.
so after building these myself this past week i disagree with 2 out of 3 of your reasons. reason 1. it didnt take much more time at all to predrill holes and fasten these together with a cordless impact and i wood glued as well for that little extra(you may not have these tools as for your reason of not fastening them together). And there is absolutely no exposed hardware anywhere. reason 2. these are supposed to be built in 2 levels. you say lifting the car that high on one corner at a time is unsafe? how do you think everyone lifts cars to get each side on a jack stand? but you are absolutely right about reason 3. these things are big and bulky and take up a bit of room. dont be offended by my post, i just wanted to clear some things up for people. I will have pics of mine tomorow for people to see. I cant wait to use these to install all of my parts!!
Old 03-24-2012, 01:33 PM
01 ss vert's Avatar
Fastening would create #3 for me - storage issues. Being individual is easier for me.
As for lifting, I think lifting 1-4 " at a time is safer than 8." When lifting, I could SEE the wheels moving on the other corners. If I built these boards 2' in length, then no worry, but with only a few inches to spare per side, rolling was nothing something I was comfortable with. Thus I jacked one end up a few inches, moved to the next corner, and repeated will all wheels had 5 board under them.
I also didn't mount them all together since I want some adjustability in my height without it being a hassle. It fits me and I have less than 2 hours in the set-up, so I'm happy.
Old 04-01-2012, 07:41 PM
mikh338's Avatar
alright well i got mine all finished up today and i added extra supports since i used reg "softwood" lumber from home depot. just cheap framing 2x4s out of pine. i have about 15 pics to show each step. i wood glued everything and pre drilled every hole before scrweing them together. they did not have 2x16s and even if they did it wouldnt be a true 16" wide board anyways so i bought a 2x12@16ft and a 2x6@16ft, ripped the 2x6 down to 5 inches on my table saw, and that gave me the perfect size for the top i needed.
Old 04-01-2012, 07:52 PM
mikh338's Avatar
let the pics begin.
let the cutting begin.
building the bases.
attaching the 2x12 on the base.
with the 2x12 and 2x6 on base.
adding the extra supports in the middle of the bases.
all of the completed bases with extra supports.
finished view of the bottom bases with supports for top pieces.
bottom view of the top piece.
here is what one complete top and bottom looks like.
and all 4 completed!!
Old 04-20-2012, 09:55 AM
metalmilitia606's Avatar
^^^ I'm about to make some of these. That looks like a really good idea.
Old 04-20-2012, 10:14 AM
mikh338's Avatar
lol do it, ive been preaching on here non stop how amazing these are and how much they helped me out. sooooo much room under the car, check out this post of my projects i did last week https://ls1tech.com/forums/suspensio...y-tomorow.html
Old 04-20-2012, 12:41 PM
I read through that earlier. It looks a lot easier than when I did mine. I did shocks and springs and all the other stuff on my back with 2 jack stands and a broken jack.
Old 04-20-2012, 12:47 PM
  #32
mikh338's Avatar
lol your crazy
Quick Reply: Has anyone built wood block jacks aka "cribbing blocks"
