Help, ABS off and break light comes on
The break light (as if my ebrake was on) and abs off light turns on after about 25min of driving. Maybe less. Any ideas as to why this happens?
Save the manuals!
Could be a wheel speed sensor or something else. You'll need to get the car scanned for ABS codes to tell exactly what's up.
Many cheap scanners won't be able to pull the ABS codes, so you'll either need to go to a dealer or someone with an advanced scanner to get it done.
Scanned it at work yesterday. If I remember correctly the abs code was something along the lines of, "electronic arm sensor malfunction", or something close to that I believe. Any ideas? Thanks for the reply btw.
