SuspensionHelp Needed
Ok so I want to lower my car and BMR is having a sale on springs and koni shocks right now.
1993 - 2002 F-Body | Handling Performance Packages | HPP025 - Level 2 Koni Handling Performance Package | BMR Suspension - The Leader in High Performance Suspension & Chassis
I already have a suspension technology front sway bar.
I plan on also ordering the Pan Hard Bar
1993 - 2002 F-Body | Panhard Rods | MPHR002 - Panhard Rod, Chrome Moly, On-car Adjustable, Polyurethane Bushings | BMR Suspension - The Leader in High Performance Suspension & Chassis
Rear Sway Bar
1993 - 2002 F-Body | Sway Bar Kits | SB003 - Sway Bar Kit With Bushings, Rear, Hollow 25mm | BMR Suspension - The Leader in High Performance Suspension & Chassis
And control arm relocation brackets.
1993 - 2002 F-Body | Control Arm Relocation Brackets | CAB002 - Control Arm Relocation Brackets, Bolt-on | BMR Suspension - The Leader in High Performance Suspension & Chassis
Is this all that is needed to complete everything the right way?
Rear Sway Bar
Your list of mods looks exactly like my list for the spring season. The only thing you might want to look into if you haven't is a good spring compressor. You're going to need one to do the fronts.
P.S. looks like you're right in my neighborhood, I've def heard of Pen Argyl before.
LS1Tech Premium Sponsor
What are you looking to do with the car? If you are looking to have a well handling street car that group of parts would work well for you, the only thing I would add if it was my car would be a set of lower control arms otherwise it will be a nice solid setup.
When you are ready to order these BMR parts give us a call.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Its good to hear from someone that lives around the area. Pen Argyl is up by Windgap. I actually work in Bethlehem.
When you are ready to order these BMR parts give us a call.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
