Bangin on driverside rear
Took it off the road cause I was feeling banging seemed to be on the floorboard to in the back. Anyway jacked up found some bolts That should have been in the other way and wore some of the pipe that held it. Fixed that put it back on the ground and just pushing on the drivers rear I hear a bang. Suspension is all new cept the springs so I have no idea right now what it is.
Any help would be welcome.
9in with watts link, Hal shocks and stock springs.
No not bumpstops. Felt it in the tire while I pushed on the rear so took off the tire and didn't find anything loose or I could move. Pressed down on the rear that noise was gone but now there's a noise up in the center now. Only thing I can think of there's very little play at the yoke that makes a noise but not the noise I was hearing while driving. This one going to be a tuff one to figure out. Swaybar is also tight with all new bushings and rubbers. Might call off work and spend a day on it.
