Car sits higher on passenger side
So im not sure if the car has been like this and i never noticed, or if it recently happened, but for some reason my car is higher on the passenger side. I recently put a new torque arm on and changed my lower control arm mounts. I've read some threads but most say the drivers side should sit higher. I tried swapping the rear springs but nothing changed, and also i made sure they were clocked the same way and that the isolater's were seated. The only thing i can think is it is something in the front end binding or bent. The car doesn't have sub-frame connectors, but the frame shouldn't be twisted because all the panels line up and the doors shut fine. Any help would be greatly appreciated.
Well i solved my own problem, im guessing i need adjustable LCA's I have aftermarket boxed arms, and with them down all the way on the adjustable rear mounts they push the rear end to far back and the coil spring is hitting the panhard bar mount.
