Want to upgrade Disc brake rotors on a 2002 TA
looking at keeping the same size that i have (OE) just want to go drilled and slotted.
i was looking at the Baer rotors but damn $200.00 plus each.
How do the summit brand rotors compare?
If you are looking for performance get some quality blank rotors and more aggressive pads like Hawks HPS (pads are what really makes the difference).
Hawk HPS Pads make a great difference in stopping power. and if you wanted a quality set of drilled/Slotted Rotors, I have the Baers in stock, and they are closer to a bit above $200 a pair, not $200 each. But the pads would be the first upgrade of choice
Mike
Mike
LS1Tech Premium Sponsor
I always suggest PowerSlot rotors with StopTech pads. Great quality performance combo I wouldn't hesitate to take around a road course...because I do.
I also suggest DBA slotted rotors. Hawk makes great stuff, but I have found the StopTech pads to be better in every way for me.
- Kevin
- Kevin
I have drilled/slotted with HAwke HPS pads and I could not be happier.
They are 10x better than my stock rotors. Anything is better than stock one you've exhausted that particular part.
In all actuality, one or the other (drilled or slotted) renders the same amount of functionality as a combo; that's what those gentlemen mean when they say drilled/slotted are for show.
is this correct
1- True Drilled and slotted rotors ARE prone to cracking
2- True Dimpled and Slotted rotors are NOT prone to cracking
talk to me guys.
thanks for your help.
talk to me guys.
Again if you want performance get a quality blank rotor with good pads.
If you actually want to stop better, then you're looking at just simple brake maintenance and better pads with new rotors.
