View Poll Results: which sfc's?
SLP Welded
3
15.79%
SLP Bolt-on
4
21.05%
BMR Boxed
4
21.05%
BMR Tubular
8
42.11%
Voters: 19. You may not vote on this poll
SFC's?
Old Mar 26, 2004 | 07:36 PM
02WS6Bird's Avatar
Default SFC's?
Sub-frame connectors....from who should i get them...and tubular or boxed...weld-on or bolt-on?
im looking between SLP and BMR but any suggestions will be taken into consideration
Old Mar 26, 2004 | 08:12 PM
XtinctHawk02's Avatar
They say the "weld-ons" are alot better than bolt on's. I am probably going to go with BMR myself.
Old Mar 26, 2004 | 08:25 PM
DARK AGE 53's Avatar
SLP or Don Goetz bolt-on SFC's have my vote.
Al
Old Mar 26, 2004 | 09:59 PM
DaveX's Avatar
I like the 3 point design like the SLP (and there is at least one other) myself. They are a bit heavier but I think they have a slight advantage in helping with chasis flex, which is what they are supposed to do. If you go SLP, the bolt ins and weld ins are exactly the same except the bolt ins come powder coated and with the mounting hardware and the weld ins come plain and will need to be at least painted. Buy the bolt ins and you can still weld them in if you want to and then you just have to touch up the welded areas with paint. I have mine bolted in right now and so far haven't fealt the need to weld them.
Old Mar 27, 2004 | 05:27 AM
smokin' joe 00 ss's Avatar
SLP bolt on's here.
Old Mar 29, 2004 | 01:20 AM
Cal's Avatar
Cal
SLP weld on's.
Old Mar 29, 2004 | 01:41 AM
95_Firehawk_Dude's Avatar
I heard that the Kenny Brown were real good. Any opinions on that? Those are the ones i was thinking about getting.
-Scott
__________
'95 Firehawk. Red on red. Stock (for now)
Old Mar 29, 2004 | 02:38 AM
tuffluck's Avatar
subframes are subframes are subframes...just get some damn subframes, it doesn't really matter which, they all will do about the same in the long run.
Old Mar 29, 2004 | 02:54 AM
Gamble's Avatar
Got the BMR Tubular... Still need to get em' on
Old Mar 29, 2004 | 10:19 PM
droopy726's Avatar
gotta disagree here, you get more ground clearance w/ tubular's but boxed ones are stronger, also theres a big difference between 2pt and 3pt sfc's.
Old Mar 30, 2004 | 01:47 AM
98sspullin'em's Avatar
and i dont care about long run, just 1/4 mile run....
im in the same boat as you man
Old Mar 30, 2004 | 03:22 AM
Bad Mojo's Avatar
I went with Spohn chrome moly tubular's. Weigh 25% less than steel, and they are 50% stronger.
Tuck up nice and tight too, can't see 'em unless your looking under the car.
Old Mar 31, 2004 | 10:49 PM
demonspeed's Avatar
It's not mine! woo hoo!
I like the way the Spohn tubulars tuck up nice like Bad Mojo said... but on the other hand, I like the boxed BMR's because you can use them as a jacking point... Hard choice, but you can't lose with either.
Old Apr 1, 2004 | 07:55 AM
markss2oo1's Avatar
I dont know why people complain about ground clearence with SFC's. There is so much more stuff under our car that hangs lower than them.
Old Apr 1, 2004 | 10:12 PM
WAHUSKER's Avatar
Kenny Browns are stronger than SLPs. But they have issues with other mods, like drive shaft loops. Which you need at the track. I have the SLP bolt-ons, and the SLP DSL. They work fine so far. Boxed are stronger than tubular, and 3 point are stronger than 2. And you can use the boxed as jack points too!
