Rear shock bolts
Rear shock bolts
2002 Firebird came from Illinois so there is some rust on a few bolts under the car
the lower shock bolts are rusted on... you try to put a ratchet on and turn .. it just turns the bolt and weird plate on the back side... what gives? any tricks for taking them off?
1/2" air gun and some heat from a torch.
use bake fluid to soak it for 15mins first.
and try to fit a vise-grip on the stud to hold it in place.
LS1Tech Premium Sponsor
If this doesn't work use a little propane torch and heat the nut and it should come off.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
