Rear end trouble!
Rear end trouble!
98 SS, just recently notice that rear sits 1/2 to 3/4 inch lower on pass side. Also driver side wheel sticks out about 1/2 to 3/4 further than pass side....sooooo its 1/2 to 3/4 inch off up & down + left & right. Its never really rode great out back + has always had some vibration. Replaced carrier bearings about 6 mo ago. Noise is gone but vibration isn't. Not sure what to make of this or even where to start in getting it fixed/ realigned. ALL expert advise appreciated!!
LS1Tech Premium Sponsor
Sounds like a panhard rod issue! Installing an adjustable panhard bar will allow you to shorten the bar and bring the rearend to the correct position, this should also take care of your ride height problem at the same time, but it may also be another issue.
What work have you done with the suspension currently?
- Kevin
- Kevin
