Outer Tie Rod
I noticed the other day that when I hit the brakes,the car would want to pull to the right.It does it during normal driving also,just all of a sudden it wants to pull to the right.
I put the car up on stands and started moving the tires around. The drivers side was fine. When I moved the passenger side from to to bottom.....nothing. When I pulled from side to side,I did get a little play,which means I'm going to go ahead and replace both of them.
Would that little play cause the problems I'm having?or should I check other things while I'm at it?
