Rubbing Sound / Adjust E-Brake??
The rotors were clanking.. I didn't secure them with a lugnut. What else could it be?
The axles were spinning, I left the car in third gear. Why would it not be the axles?
If the car is rolling it makes the sound, (in gear or not) I apologize if I stated differently, when it is sitting still running, there is no sound....I could rev it, still no sound
I posted a similar thread about two months back about a consistent rubbing sound coming from my rear.
It sounded like my rear rotors constantly rubbing while braking and also when not braking. It is constant...
I thought it was my rotors so I bought new rotors and new pads 100 miles ago and the sound went about 40% away, now it is back in full force...
This sound has been annoying me for so long that Saturday I am actually taking it to the family mechanic. I just dont have the time with work to do it myself...
My question is:
Can this be anything else but my e-brake needing to be adjusted? Anything at all that you guys may think it could be.
Cause I am going to drop some money now and I would like to maybe point them in the right direction so it wont cost me as bad as it could..
Thanks guys
My question is:
Thanks guys
#32
Scrubbing noise from rear wheel
Holtrop21 I know this is old but I am experiencing the same with my rotors. Spin with rotor no caliper have scrubbing, spin with no rotor no noise. What did you figure out?
#33
Same issue.. It's the E-brake shoes getting out of line
I'm having the problem: rotor on I get noise, rotor off no noise. I finally figured it out if anyone else has this same issue in the future or still trying to figure it out.
It's the E-Brake shoes that are making the noise, they don't sit right and shift when the E-brake is used. Once the E-brake shoes are adjusted correctly you want them to grab and hold the car up to 1,250 rpms to pass inspection and to hold the car on a hill. The thing is once the shoes are set in place where you want them and put everything together you can't see it, but once you first use that E-brake for some reason the shoes will shift off center and not re-align giving us this dreadful noise we all hate that won't go away. A lot of us thought it was the rear-end differential or bearings, but it wasn't. It's the stupid Emergency brake shoes slightly getting off centered and not correctly lining back up after using the Emergency brake.
What I think is happening is that there's a screw and a plate that's SUPPOSED to HOLD the Emergency shoes on top in place. After adjusting and aligning the E-brake where you want it put that rotor on for the last time nice and flush against the shoes. Spin the rotor. Do you hear it? You shouldn't, I didn't. That sound went away.
So what I would do guys who are having this trouble, adjust E-brake where you need it to be enough to grab the car on a hill and 1,250 rpms hitting the gas while engaged for inspection. When you figure out your sweet spot, take everything off again. Yes I know it's frustrating, but we've all done it. Take it off, take the rotor off. Notice that when you take the rotor off.. having a little trouble like the shoes are rubbing. Look at the shoes, make sure they are centered and flush to the backing plate and rotor. So now, when you put the rotor on should go on smoothly. Put the bracket on and spin the rotor before the caliper. The noise went away! It did for me and it should for you. Don't forget to do both sides and it will go away. But guess what, if you use that E-brake just that first one time that noise will come back. TEST: DO NOT TOUCH OR USE THE E-brake and go for a drive. Do you hear any noise? If the noise completely went away, its your Emergency brake shoes that stopped rubbing after you re-aligned them and its not the axle or bearings. If you still here a noise then its something else it could be your axle or bearings.
But remember, once you use that E-brake after driving that noise will come back on and you will have to do it all over again. I haven't fixed mine yet, just figured it out and wanted to pass the info forward. For some reason that screw and plate doesn't hold the shoes as it should on top and when the E-brake is engaged it shifts the shoes out of align ever so slightly enough where we here them rubbing. I'm goin to try and fix mine soon. I'm going to try and find a new plate and screw that may be stronger, like brass because I think this plate metal is weak and over time doesn't hold the shoes as it should causing them to shift after we just adjusted the E-brake perfectly. Hopefully with two new STRONGER plates, screws and newer shoes (could be warped) they will stay in place I can get this dreadful sound gone. I will post an update when completed!
#34
Save the manuals!
The factory procedure for adjustment is in this thread and will give a precise hold: https://ls1tech.com/forums/suspensio...ke-01-z28.html
While servicing the brakes, one might want to upgrade the dust boots: https://ls1tech.com/forums/suspensio...xperiment.html
#35
Every time the rear rotors are changed or machined, the emergency brakes need to be adjusted to fit the new bore of the rotor hat. You are correct that any drag is going to create noise until the brake material burns away. That screw and clamp doesn't hold the pad securely. It just helps it center up when released so it doesn't move too far off the mark from the actuator. (The pad moves around in this clamp normally, but may seize up a little bit over time as things gunk up and rust - no big deal; it all cleans up during servicing.)
I never looked at or cleaned the inside of the plate, Dust boots, pushrod or brake lever. Next time I get under there I will take a look on the inside of the plate and clean up the dust boots, pushrod and brake lever. I will probably add some nipples too keep it extra protected!! Maybe something on the inside is rusted or dirty by the lever causing it to seize up a little not allowing it to Fully dis-engage and center the park shoes correctly. I'll take a look at the park brake lever, spring and cables could be hung up might give it a little tug too.
Here is a diagram if anyone ever needs it as a reference: Parking Brake Parts
What I was trying to explain what was happening earlier, in this diagram the Top part of the Park Shoes were not aligning back up to #2 The Screw and #3 The Hold Down Spring. It would shift off center, just even using the Park brake one time. I will take those off give them a real good cleaning and put them back on one more time. It looked like that Clamp Hold Down Spring wasn't centering the shoes back to where they are supposed to be that may be Seized. But when I was looking at it last it looked like I could turn that screw more make it tighter to Hold that clamp spring down more which would hold the shoes in place better.
Once I have time to do everything I will post and give update if it worked.
#36
Save the manuals!
This was ;my first thought when I was reading your first paragraph. I think if you disassemble the cylinder, the adjusting screw, the pin in side, and the lever and then lube that all back up, things will center up nicely. The fact that your shoe is ending up off-kilter makes me think that those internals aren't sitting on the actuating lever correctly.
I'm also going to replace the shoes, I bought the car like this so I don't know who did the work before me because I could tell they were newer or if it was even done correctly for that matter. All I know is that it could have the wrong shoes on there and not know lol. I'm going to get New Shoes so I know exactly what's on there and like WSSIX99 says going to disassemble the: cylinders, adjusting screws, the pins inside, and levers lube them all up put them back hopefully that will fix it and center the shoes back up correctly! Let you know in a few weeks...
#38
Type of Lube?
Thanks
#40
From the Diagram above (Our brakes are flipped upside down): I have to loosen the screw (#2) to the Clip (#3), but it's a pain to get in there do I have to take the clip out or just loosen? Any tricks you know of? I guess I have to use a right angled screw driver to get in there? I lubed the screws up with WD40 and letting it sit overnight so it doesn't strip when I loosen them hopefully it doesn't give me an trouble tomorrow. Also, I have to take the two screws (#13) out of the back plate to take out the cylinder and adjuster (#5,7,10) to lube, correct?
I'm just making sure I'm doing this the correct way because I don't want to strip or snap any of these screws that wouldn't be good because (#2) is hard to get at and (#13) are little rusty.
Any input would be helpful!
