Strut Tower Brace worth it?
My front tires should be good, honestly haven't checked them lately, but the rear that I even started considering an STB was because I just installed BMR LCA's recently and at speed, maybe 60+ mph it felt like the front end got a little floaty, at least according to my buddy who was driving the car at the time. He doesn't own an f-body though so it could be normal. He said a STB may tie the front end together to eliminate. that I haven't driven my car for about 2 weeks, I'm waiting for the PHB to get here.
On another note, are you guys anywhere NEAR being finished with the 3rd gen F-body, LS-v8 swap, "road race" K-members yet. My roommate had ordered one 4 months ago for a project car that the both of us are building and was told that they are making some revisions before final shipping.
Any progress??????
You can add a STB and the car will still be just as floaty. Your springs and shocks control your front suspension travel. Stock shocks are junk and aren't dampening anything anymore for you likely... so your springs are just bouncing around freely.
I'll try driving the car once the PHB and STB get here and are installed. Like I said, my friend was the one driving so he may not be used to the car and it could be fine. I did drive the car after he did but I wasn't going 70+ mph and thats where he said he felt it so I'll drive that a try whenever the parts come in.
I definitely can't afford coilovers right now, but I did see a Bilstein/Eibach package for $611. Or just the Bilstein shocks are $3xx for all 4.
#32
Being I'm thinking about it now....if your car isn't tracking right, maybe it's not a bad idea to get an alignment before putting money into it. There's a chance it's all you need. A 1/16 degree or so of toe in (not enough to hurt tire wear), along with good caster (a little higher on the right side, 4.5 degrees left/5.0 degrees right for example) might solve your problems right off the bat. Good shocks though, like the Bilsteins, are probably a good investment regardless and will likely make the car feel more under control, even more so than chassis modifications.
#33
Maybe I'll bring my car to a local tire place and have them check the alignment then. Last time I had my car at really high speed was about 9-10 months ago, 125+mph on a deserted highway. After 120 I could feel it start to loosen up a bit. I am installing a UMI poly/poly adjustable PHB on Monday with the STB (as long as it gets here on time from Founders). I'll swing by the tire place after that.
I could probably swing for a set of the SLP Bilsteins, I just really want my torque converter!
#35
UPDATE
Got the STB and PHB installed tonight. Took maybe a half hour total. I only did a visual inspection of the PHB to get it lined up properly. I did it at a buddies house because he has a pit dug out in his garage for working under the car, and his house is off a couple twisty-ish roads. I decided to see if I could feel any difference. It could just be in my head but it did seem to make a subtle difference in keeping the front end tidy on that road. Other turns I took a little fast and didn't really notice a difference. I think maybe circumstances just have to be right to feel a difference, speed, line, etc.
I also got the car up to 90 and didn't feel any floatyness so I think my buddy is just used to more solid cars, like his buick or G8
#37
I bought a stb, lcas and a phb with my new 12to bolt 4.11 gears. Take off now the back wheels do not hop and the car feels stiffer as not twisting as much and on turns it feels like it hugs the turn alot better. All around the handling of the car i feel more in control
#38
I was told by a buddy who is a seasoned road racer that the STB shows it's worth under heavy braking.
If you have road raced a F body you know under very heavy breaking the car tends to dart around some.
I haven't installed on yet, but I will before the fall when we go racing again.
#39
Personally I love mine!
(Mine is also UMI)
From my personal experience it REALLY tightened up the front of the car and made it feel so much stiffer and turned a lot better IMO.
BUT literally 2 days after I did this my Power Steering cooler broke and I had to flush the coolant and PS... but regardless, it did two things for me.
1. Tightened up the front
2. Looks great in the engine bay!
(Mine is also UMI)
#40
I've spoken with a few auto body shop owners about strut tower braces for our cars and they've each offered this unique perspective: As our cars age, the weight of our engines begin to pull their front fenders inward and down. I have been told that strut tower braces will mitigate this problem. Do I believe this? Well, it certainly makes sense. Can I prove it? No, but since I put mine on 10 years ago the very day I bought it brand-new, I'd like to think that I made a "solid" investment.
