bmr ta001 rod end size, broken
The upper rod end by the torque arm mounting bracket, on the top where it connects the torque arm to the bracket on the diff, is loose around the bolt holding the rod end in. I'm pretty sure it's from wheelhop from my stage 3 clutch install, it rattled alot of things loose and broken. I need the rod end size so I can take it out and replace it, if anybody knows..thanks!
