How to get a lower 60ft without sticky tires?
Old 06-27-2012, 10:09 AM
k_garretson23's Avatar
Default How to get a lower 60ft without sticky tires?
I have all the mods in my sig. Im on a stock 10 bolt so I do not want to use sticky tires yet. I also have bmr lowering springs on the way. How can I get a lower 60ft without using dr or slicks? The best 60ft i can cut is a 2.2. I spin a good amount.
Old 06-30-2012, 08:17 AM
02 SSilver Bullet's Avatar
You've got to get your tires hot at the line and not dump your clutch on the launch. Ease into a quick roll while holding RPMs around 1800-2000 and then stomp it. If you still have stock gearing you can try shifting 1-2 quickly if you're still spinning w/ this technique. 2nd gear will still carry you out quickly. Your 100ft time might increase too. This has worked for me. I still don't have slicks or DR on mine.
Quick Reply: How to get a lower 60ft without sticky tires?
