AERODYNAMICS and GOLF ?
There are two types of aerodynamic drag that an object experiences as it travels through air. The first is drag from laminar flow over the surface of the object. The second is pressure drag, which is the result of a low pressure area developing behind the object as it travels. At high speeds, this low pressure drag can be a significant amount of drag.
Since a sphere is a sphere, there's not much you can do to reduce the drag from air friction. However, the dimples on a golf ball create a turbulent laminar flow along it's surface, and this flow actually follows the contour of the sphere longer, which reduces the amount of pressure drag, thereby allowing the ball to travel further through the air.
Cars and airplanes aren't spheres, so they're able to design far better aerodynamics into their shapes, so in most cases the significant portion of drag is from air friction, not pressure drag.
