Need suspension opinions 2000 Z28
2000 Z28 A4
Possibly converting to M6 later if that matters.
I want you guys opinions. Please factor in cost effectiveness, quality and you guys experience. I'm torn I'm an occasional midnight madness dragstrip racer but I enjoy my curvy backroads and would love to get into occasional auto X one day.
I would prefer a balance of both which I understand is hard. I want to shoot for a setup to handle 450-500rwhp. Also would respect if you guys could recommend the order that I should possibly do step by step. I have looked at packaged suspension / handling kits that are just way to pricey for me at once right now. I appreciate and respect any of you guys personal opinions. Thanks.
Good Shocks, Springs..... LCAs and SFCs are a must i think for any f-body. Especially SFCs if you don't have them yet.....
Although there are cheap parts out there you get what you pay for. Going cheap on your springs and shocks can cost you poor handling. Not saying go out and buy the most expensive shocks and spring combo but their are some great shocks and springs out there like Koni, Bilsteins, KYB, or Tokico shocks.
That's my .02 Good Luck
Thanks, I guess what I'm stuck between is I want some traction for the track but I mainly 99% of the time drive it on the street. I want ok~decent straight line traction and excellent corner traction. Is this too much to ask lol. Maybe a compromise of a full adjustable shock or can someone elaborate on coilovers?
Good shocks and UMI 3-point subframe connectors are a great place to start. After that, a UMI Panhard Bar and Lower Control arms.
Our stuff is all made by skilled craftsmen and craftswomen who care.
The whole dual purpose car thing is tough but doable if you keep your expectations reasonable.
Ramey
Ramey
Got some very good looking products. I see front spring rates go from 300-325-350 online. What's good spring rate numbers for the rear and how do they associate with handling / traction?
2000 Z28 A4
Take what the drag guys say with a grain of salt, as most drag parts will kill handling/stability/balance of the car. Things like heavier rear ends, locking differentials, poly bushings, short chassis mounted torque arms, drag shocks, overly soft springs, overly large rear swaybar etc etc.
Good shocks (not cheap autozone replacements, or drag shocks) will make the biggest difference, and will IMO "make or break" the setup.
If I were in your position I would just start out with some good shocks (Koni SA's preferably) and sticky tires. That alone will make the car corner drastically better(better grip, balance, feel, control), and give a better, firm but not jarring ride. The car will really feel glued to the road.
There are a handful of good handling adjustable coilovers out there (KW, race bilstien, Penskie) but you will be paying a pretty coin. Also consider that you can't really adjust height "on the fly" as you will need an alignment every time you change the height.
Stick with your stock springs for now, and they will be a good balance between weigh transfer and handling. As I said above, the big thing is to get some good shocks.
From there maybe some matching swaybars (35mm front, 22mm rear-no bigger). A full length torque arm, and you can relocate it off the transmission if you want. Maybe some rear LCA's if you feel they are necessary (but no poly bushings as they will bind). SFCs are also optional, as once you have good shocks on I honestly doubt you will feel the difference SFC's add.
JD thanks dude that seems like some pretty good info. I will look into some good shocks. I had a 300zx twin turbo with eibach springs and tokico 5way adjustable shocks and that car handled like a dream with 275's all the way around. Granted that car had IRS but I love the shocks. One setting gave a great ride and the other made it so firm you could barely push the car down. I hope to find an option close to that.
Also if you get serious into racing you can fit 315s on all four corners of these cars.
