Squeak / Creak over bumps and rear brake howl
OK, I've searched and searched.
My 2002 Camaro SS LE with stock suspension makes a terrible squeak/creak, groaning noise over bumps, going slow or at speed. You can hear the noise outside the car, its kind of embarrassing.
The car does have bolt in sfc and a stb.
What should I check? Do I have to take the wheels off to check any of the bushings
And, I have a weird brake howl coming from the rear. I'm pretty sure its the brake because it only happens at very low speeds, after the brakes have been applied to bring the car to a slow stop. For instance, I can pull into my driveway, apply the brakes very lightly to stop the car slowly, and right before it comes to a complete stop it will howl for just a second. If I come to a regular stop, like in traffic there is no noise.
oh, and just to add to the confusion, no noise this morning on the way it to work.
temp - low 80's. the longer you drive it the more noisey it gets, even on hot days
Thanks guys, I'll check that stuff.
I'm thinking of upgrading to some brake motive slotted rotors and pads, can't beat there deal for a whole set.
