vogtland lowering springs? SLP bilstein shocks.
#44
LS1TECH Sponsor
You are welcome. Thanks for the business. You only need the fronts, the rears have no such parts. There were various brands, Moog was one but I don't recall the part number off hand.
__________________
#47
LS1TECH Sponsor
There is an isolator which sits on the perch. All springs sit in that, I'm sure that you have on your current shocks. You need the metal perch, that sits on the clip on the shock which in turn the isolator sits upon (and the spring on top of that).
__________________
#49
LS1TECH Sponsor
From what I can tell based on not so good pics and the description, yes.
__________________
#50
Ok thanks, now I have more questions lol, I want to get LCAs but dont know if I should go adjustable or not, or which one to get (brand, material, and such), I want to improve traction since there is any even with dragradials what is your advice? Also In goung i get the adjustable PHB which brand do you suggest? (I would like to keep everything same brand)
#51
LS1TECH Sponsor
you only need adjustable if you have some sort of issue where the axle isn't straight in the car (you can see that on an alignment rack), or you are planning on another rear axle where the mounts might not be welded on exactly the same on both sides (leading to the same issue I mentioned, the axle crooked in the car).
I sell, use, and recommend UMI parts. There are all kinds of LCA's, I'd recommend a combination Poly/Roto-joint arm like this: http://www.stranoparts.com/partdetai...D=96&ModelID=7
There are adjustable versions, and ones that have roto-joints at both ends too. I would not recommend all poly bushed arms, most especially with the springs you picked up on the cheap and their high rates.
The Panhard bar can be poly bushed on both ends without the downside the LCA's will pose (binding in roll). However, poly stiff deflects and a roto-joint or rod-end has less play than the bushings. PHB's are found here: http://www.stranoparts.com/searchbym...D=67&ModelID=7
__________________
#53
LS1TECH Sponsor
Yes, and not in a good way. Pro's are straight line grip. Con's are roll oversteer.
__________________
#55
LS1TECH Sponsor
Absolutely not.
__________________
