Torque arm adjustable or non-adjustable?
Old Aug 15, 2012 | 02:27 PM
1994_383_Z28's Avatar
Default Torque arm adjustable or non-adjustable?
So long story short, my torq arm is broken right where it mounts to the rear end. This is the last stock suspension piece I have, so I figured it's time to go aftermarket. Now my question is should I buy the adjustable or the non-adjustable one? I don't have a clue how to adjust it,and don't want to end up with an improperly adjusted torque arm, but at the same time the adjustable must be better, right? It is only a $60 difference in price, so the money does not matter. What should I buy?
Old Aug 15, 2012 | 03:25 PM
Also what brand do you think I should go with? The only website I checked out was UMI just because I usually have good luck with them.
Old Aug 15, 2012 | 04:30 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Since I assume your car is lowered from your signature I would run the adjustable torque arm. The change in ride height will effect the pinion angle a bit and having the adjustable torque arm will allow you to fine tune the pinion angle. If there is something we can help you out with let me know.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Aug 15, 2012 | 04:36 PM
Kyle
Thanks for the response Kyle. My next question is how does the bmr differ from the other brands? I need to order one tonight and I don't want to regret my decision.
Old Aug 15, 2012 | 10:27 PM
kylemm1002's Avatar
If your lowered get adjustable for sure! I just installed a umi tunnel mounted adjustable TA. Fit was perfect.
A lot of people prefer a long arm over the short tunnel mounted one. If you get a standard length arm I'd get a relocation cross member to get the TA off the Trans.
Lots of info on here trying searching around and reading reviews.
Old Aug 16, 2012 | 07:32 AM
UMI Sales's Avatar
Good morning.
If you already have our T/A relocation kit (THANKS!), you could use our adjustable 2205 along with the 3003 bolt kit.
http://www.umiperformance.com/catalo...roducts_id=130
The 2205 comes with the bushing and will fit right in your relo bracket up front.
Have a great day.
ramey
Old Aug 16, 2012 | 07:51 AM
garygnu's Avatar
with all the good suspension parts you have a adjustable torque arm would compliment them.
Old Aug 16, 2012 | 07:53 AM
BMR Sales2's Avatar
The one place our torque arm is better then the rest is in the mounting bracket. Our mounting bracket is designed and braced a little different then the rest so it will pretty much take anything you can throw at it. As long as you get a good quality torque arm you shouldn't have any issues with it down the road.
Give me a call here at the shop and I will see what I can do or you on pricing of a BMR adjustable torque arm.
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Old Aug 16, 2012 | 08:02 AM
BrianSF-GA's Avatar
I wouldn't consider anything other than an adjustable ...
