Sway Bar
35mm/22mm are a common handling set for these cars.
Solid vs hollow is personal preference weight-wise. I can't speak for every manufacturer but the popular sets of hollows with diameters similar to 35/22 tend to be slightly lower in rate while still maintaining the same balance. Most of the sway bar action happens on the metal around the outside diameter (the middle is just along for the ride).
Tell us more about how you plan to use your car.
ramey
ramey
You want a good guideline to start from? Go with the strano swaybar set. If you want to save a little money, go with a 32mm front bar and stick with the stock rear.
Hollow saves you weight while being nearly as stiff as a solid bar of the same size.
stranoparts.com
