Stock PHB
Old Sep 20, 2012 | 10:05 PM
ryany's Avatar
Default Stock PHB
Does anyone know the measurements of a stock panhard bar for camaro hole to hole? I have lost mine and trying to get a good start point for the bmr panhard bar?
Old Sep 21, 2012 | 10:03 AM
DarkJuggalo's Avatar
i can try to dig mine out for ya, but wont be until the weekend
Old Sep 23, 2012 | 05:10 PM
leadfoot4's Avatar
You mean an adjustable PHB? Simply install it, and then "center" the rear end under the car.....
Old Sep 23, 2012 | 06:09 PM
need4fun2469's Avatar
when you take the factory one off, lay the bmr rod next to it and adjust it. You will still have to center the axle once it is installed as said above.
Old Sep 27, 2012 | 05:17 PM
eb110americana's Avatar
Sorry, I've been meaning to reply for a while now (had the tab open since the OP). The original OEM bar is 43 & 1/16" from center-of-hole-to-center-of-hole. Mine has been sitting out back, so I just measured it for you. As the other posts say, if you're going lower, you'll need to go shorter than that.
Old Sep 28, 2012 | 12:19 PM
leadfoot4's Avatar
Actually, you'll most likely need to go longer, if you're lowered.
