Alignment Specs-Stock Ride Height
Found a few threads with search but they mostly discussed specifications for a lowered car. I will be at stock ride height. Just replaced upper/lower ball joints, inner/outer tie rods, A-arm and sway bar bushings. Wanted to get a bit more aggressive alignment without creating too much uneven wear.
-1.3 camber
4.5 caster
zero toe
Saw these for a lowered DD. Would that be OK for stock ride height?
Forgot to add: Will be temporary DD for 3 months but usually just a weekend car.
-1.3 camber
4.5 caster
zero toe
-1.3 camber
4.5 caster
zero toe
-1.3 camber
4.5 caster
zero toe
