Need help, shifted parts (PICS)
So iv'e been hearing like this, metal on metal chirping in my left front wheel for the last couple days, I finally had the time to get it up on some ramps today and noticed this right off the bat. 2 different bolts.
I just recently got quite a bit of work done (2 Front hubs / Rotors + Pads / alignment) and and after the alignment it started making noise. Now im a suspension newbie is this normal for them to adjust those in an alignment or is that the entire assembly shifting? Going to go and see if there loose/tight now, update soon.
I doubt they moved the a arms during the alignment. Is it driving straight? If so I say tighten the bolts where they are. I doubt that little deflection will affect the right side.
When they finished alignment, they failed to make those 2 bolts sufficiently tight.
( they would have moved the arms a very small amount, but not by the amount shown in your pics )
those are the adjusting points to adjust the caster and camber ( part of the setting for alignment) the align tech may forgot to tighten them after aligning or they maaayyyy
have just worked loose,
in 35 years doing alignments I have a few work loose ( most time with this problem I just did not tighten )
Johnny
Johnny
