Just got my Strano Spings......
Are Strano springs real hard on stock shocks? I'm not trying to knock the springs at all and I know they they are probably the best springs for our cars. I'm just wondering cause my DMS springs have been fine with my stock decarbons no bounce or anything. The car looks awesome, and the drop totally changed the look of the car, I saw it in real life so I know how drastic it changed the look of the car
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Are Strano springs real hard on stock shocks? I'm not trying to knock the springs at all and I know they they are probably the best springs for our cars. I'm just wondering cause my DMS springs have been fine with my stock decarbons no bounce or anything. The car looks awesome, and the drop totally changed the look of the car, I saw it in real life so I know how drastic it changed the look of the car ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The decarbons don't necessarily do the traditional "blown shock bounce" and shocks won't affect the ride height. They just generally ride poorly.
I was just curious because the ride and handling of my car did not change at all after I put the springs, thats why I asked if it was a strano spring thing. I know shocks wont affect ride height, I was just saying the op's car looked a lot better at the end of the day with the stano springs than it did when he first started. Sorry to high jack the thread.
LS1TECH Sponsor
Looks great! Thanks for taking the time to post the pics!!!!
Sam
Sam
__________________
Take your time man. I commend you for doing it in small steps because then you get to see/feel the change each part makes once its installed...is it more hassle? sure it is, but you get to learn something and in my experience you can't put a price on that.
lots of folks love the bilsteins...and they are very good and reasonably priced. Konis are also good but i wonder how much value it represents if the car is only for street use...
LS1TECH Sponsor
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
LS1TECH Sponsor
Stock dampers lack rebound, which is what damps the sprung weight of the car, and the energy stored in springs. Lowering springs are stiffer (more energy to kill) and of course shorter. Shocks work by pulling a piston through oil, and the less travel they have to do that job, the less well the job is done unless you up the damping control so that you can deal with those forces (again which are up due to more spring rate) in the shorter amount of working travel.
__________________
#33
How do you judge that? I much prefer Koni over Bilstein myself, even for "just" street driving. If everyone was opting to run their Koni's full soft, then I'd say there wouldn't be a lot of value in the performance of a Koni, but that's not generally the case. And fwiw, I see much more value in damping you want and like than I do in having 500hp in a street only car. 500hp doesn't make the car more stable, stop better, ride better, easier to drive quickly, etc. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Is the car making 500hp? or is there a plan to take it to 500hp?
#34
i have a set of konis 4/4s on my car and they are good, no doubt. i have friends that run bilsteins and it is also a good shock. if I wasn't competing I wonder if they worth almost double the price of the bilsteins for street driving? Sure the konis are better but in terms of value will the bilsteins be taken to their limit?...of course the purchaser's definition of value determines that. if the value is defined as optimum performance then yes, Konis are the answer. If value is defined as "the best i can get for the dollar I've got" then the bilsteins are a good option IMO. it certainly is a matter of preference and only the purchaser truly knows what they want.
#36
#38
#39
LS1TECH Sponsor
My shocks? You mean my springs? In all honesty they are completely different sizes and the rears look like stock rears, the fronts look like stock fronts....
__________________
#40
LS1TECH Sponsor
__________________
