Mini tub how wide and tall of tire and wheel width
I’m looking at doing a mini tub soon too, from what I see doing to tub is the first half then you have to do the lca relocation and I believe some trimming on the pan hard bar mount. I know you can fit 315s with this and honestly that more than enough tire for most applications. Search for mini tubs and you can usually see what tires those guys are running.
The Wolfe mini tub allows a 316/60-15 drag radial. It barely clears the LCA, with a stock rear. Any wider I would relocate the control arms inward. We spaced the heim joints towards the inside of the mounts on the car and rear to help.
