Lowering Kit Suggestions
Old Oct 19, 2012 | 09:14 PM
Rolandt's Avatar
Default Lowering Kit Suggestions
i have a 2000 Camaro SS put the RT-S Welds but need it lowered cause its sitting a bit high, any good kits?
Attached Thumbnails Lowering Kit Suggestions-059.jpg   Lowering Kit Suggestions-053.jpg   Lowering Kit Suggestions-044.jpg   Lowering Kit Suggestions-043.jpg
Old Oct 19, 2012 | 09:59 PM
cookba's Avatar
https://ls1tech.com/forums/suspensio...-tech-faq.html
Old Oct 20, 2012 | 02:26 AM
need4fun2469's Avatar
look at Sam Strano's site for his lowering springs.
Old Oct 20, 2012 | 07:09 AM
Rolandt's Avatar
This is the set up i was looking at.. yes or no?http://www.ebay.com/itm/320995567713?redirect=mobile
Old Oct 20, 2012 | 08:23 AM
1QWKT/A's Avatar
That's super cheap. Depends on if you are going for price or quality. If you want quality...go with the Stranos.
Old Oct 20, 2012 | 10:05 AM
Rolandt's Avatar
I'm really going for something that's going lower it around 2"
Old Oct 20, 2012 | 10:33 AM
JD_AMG's Avatar
"Spring Rate: Front: 450 lbs/in / Rear: 250 lbs/in"
lol......
Please do a search, this topic has been covered countless times.
Those springs are unbalanced as ****, and those shocks are low quality turds, expect terrible ride and sketchy handling.
Do you care about ride, handling/stability/feel/, and traction or do you just want to be lowered?
Old Oct 20, 2012 | 10:58 AM
therealcreeper's Avatar
what are you doing with the car? drag/daily driver/autox/road racing? as far as the link you posted, I wouldn't run a no name brand spring described in the title only as "red." also, the spring rates on those springs are...
...which in my opinion is extremely stiff in the rear for a street car. I haven't personally owned those shocks but my assumption would be that they wouldn't handle a spring that stiff for very long.
also keep in mind if you lower it 2" you're losing tons of travel, messing with your rear lca angle, pinion angle, and offsetting the rear end to one side. ideally you'd want more parts to correct all of that as well.
in my opinion if you MUST lower it more than 1.5"ish your best bet is Koni Single Adjustables on the lower perch with Strano/BMR springs and JasonWW's upper mount mod. I'm not the guy that says you need Koni is every single application but for something that low you need a higher spring rate, and for a higher spring rate you need a shock that is capable of handling it.
to be honest if you've never ridden in a car with anything other than stock shocks and only care about looks then the ebay link, or the eibach sportlines with an average shock would feel okay for a while, just saying that there are things soooo much better out there
Old Oct 20, 2012 | 11:44 AM
Lizard King's Avatar
Are those 17's or 18's? Just curious.
Old Oct 20, 2012 | 05:38 PM
Rolandt's Avatar
im just gonna be driving it i just bought it, it dont even have 100k on it yett but id like to get it sitting level and a little lower, im trying get peoples opinions first before i go out and buy this stuff, i really have no idea what to get.. and there 18's all around
Old Oct 22, 2012 | 09:29 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Two things...
One, those shocks they have pictured are 100% NOT compatible with the F-Body. I never buy products from anyone who can't even show me the actual parts I'm buying.
Two, those spring rates are dreadful. The rear is ultra stiff, and the front is soft.
While eBay may delight with its tempting prices, think before you buy. Those KYB shocks are...well, not good. Those springs are, at best, questionable. I can set you up with some Bilsteins and our lowering springs for less than $300 more than that and you'll be getting a proven combo and lifetime warranty springs that work well.
Let me know!
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Oct 22, 2012 | 11:41 AM
Sam Strano's Avatar
LS1TECH Sponsor
http://stranoparts.com/partdetails.p...D=90&ModelID=7 $620 gets you good shocks, great springs. Proven, durable...and never suddenly redesigned like some others around here....
See cars here for what they look like: https://ls1tech.com/forums/appearanc...ring-kits.html
__________________
Old Oct 22, 2012 | 09:34 PM
Rolandt's Avatar
Will one those atleast lower it a 1.50"? Cause its sitting pretty high
Old Oct 23, 2012 | 09:32 AM
BMR Tech2's Avatar
I want to say that your car sits unusually high. I can tell you where your fenders will sit after our springs. Saying it's a 1.25-inch drop is actually just an approximation from the average factory car. Yours looks to be much higher in the back that most cars I've seen. I wouldn't be surprised if some strange spring is on your car to be that high. Our springs would make your car look good.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Oct 23, 2012 | 10:47 AM
Rolandt's Avatar
From my finder to my tire there's about a 2 3/8 gap
Old Oct 23, 2012 | 11:49 AM
Sam Strano's Avatar
LS1TECH Sponsor
You don't want no wheel gap, then you have no suspension travel. If you review the link I posted of customer's cars with my springs, you'll get a really good sense of what your car will look like. The drop can vary, not because my springs do, but because there are so many different stock ride heights. In the end, my springs are my springs, and your car would look pretty much like the rest on them because they are on the same springs, which isn't the case stock... there are lots of different stock springs.
__________________
Old Nov 1, 2012 | 09:49 PM
Rolandt's Avatar
so i ordered it and it didnt ask for paypal or a credit card but says the order has been submitted how does that work?
Old Nov 1, 2012 | 09:50 PM
Rolandt's Avatar
Old Nov 1, 2012 | 09:56 PM
SilverSS07's Avatar
Sam will call you to take payment over the phone.
Old Nov 2, 2012 | 06:52 AM
Rolandt's Avatar
Oh alright thanks
