Installing Adjustable Panhard?
"The best method for adjusting the panhard bar is to have the car sitting with the suspension loaded. This is best accomplished on a four post lift, but if drive-on ramps are all you have access to, then they will work. Put a nut or some small weight on the end of the string you will tape on the top of the rear fender. This will give you and accurate control and not a string being blown around by the wind. Once you have taped these to the top of the fender hanging over the wheels, measure the distance from the wheel to the string on both sides. If you're car is lowered, you'll probably find it favoring the driver's side of the car. Now, go underneath the car and shorten the panhard bar a little bit and measure the change. You'll want to get both sides to have the same length and you have correctly adjusted it! Hope this helps. It's something you can do easily on your own without a shop".
Any other suggestions, tips, or tricks that could help would be appreciated!
-Matt
-Matt
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
- Kevin
- Kevin
(/ < lower, (- < level, (\ < higher.
