Ready to do away with tramlining
i swapped front to back so now I have a matching set of about 65% tread hankook 235 50 16's in front and was really hoping this was my issue
Making the swap did help a lot, though there's still a noticeable amount of pull going on
I'm thinking more than likely this is a tire size issue, and if not what else could I look for? I've had it up on the lift several times recently and check most everything out. Greased ball joints and tie rod ends, check for play or torn boots ext...
One way or another my real question is, in buying new tires, what's the recommended sizing to eliminate this problem
And sorry, misunderstanding, unevenly worn from tire to tire. The drivers side was a newer tire and had more tread than the passenger..
Another thing I'd noticed in changing my brakes, the drivers side was worn more than the passenger side. Don't know whether or not this is related... I just assumed I needed to go through and bleed the brakes
Is there anything one can do to possibly beef up the steering?
Have you checked to be sure your tie rods, ball joints, etc are all OK? In my case mine have some wear and I think that's part of it. As 97Formula said, the "allowable tolerance" can also make a big difference. Example, my Trailblazer was aligned, in tolerance, but after I had it realigned by another (better) shop after hitting something in the road they got it better than simply "within allowance" and it tracks and drives much better. It is amazing how so little can actually make so big of a difference.
- Kevin
check your tires for uneven wear as well - if you cant tell, simply take some chalk and mark a big line across both front tires, shoulder to shoulder. Take the car around the block and look and see if you have any light spots where the chalk didnt wear off. If they're worn on the outer edges = too much toe-in, worn inner edges = too much toe-out.
Toe-in helps high speed stability, toe-out helps low speed cornering... too much of either will pull the car all over the road (tramlining) as the tires fight each other for control
The way I look at it is that if I can adjust my alignment at home and save a buck
Then that's my rout
I actually was able to adjusts tie rods a couple years ago on my caddilac.. Had it tracking dead straight, though the wheel was a little off center
