Is it recommended to get new springs for heavier LQ9 swap...or no?
Ok I just got my 421 LQ9 ... however being that its about 80-90LBS heavier... now that the car is apart, should I swapp out the front springs?
will the car sink down from the front a bit more?? I think stocks springs are made for 275lbs each. But I can get 300lbs or even 350 for $50 each.
I have seen 408ci LQ9's all over the place with stock springs and I don't think I see much difference. My car has an xpipe and in texas the roads are **** ...even at stock height my pipes have scratched ....so lowering is out of the question.
Thanks for info!
Thanks for info!
Thanks for info!
Thanks for info!
http://www.angelfire.com/my/fastcar/suspension.html
If I were you i would just put the engine in and see if you notice a difference. If you don't like the way it sits/rides, then change the springs (and shocks) out.
LS1Tech Premium Sponsor
The front of the car and how far it will sink down will be determined by spring rate. We've seen as much as an inch to as little as a marginal difference, so it's going to be difficult to gauge.
You may like the look of the sunken nose...most do, then perform the heater hose mod in the rear. If you need anything to bring the nose back up, we offer a .5-inch spacer that will bring the nose back up and they can be stacked or even cut if you need more or less.
Let me know if there is anything we can do, but I would suggest throwing it back together as is before spending your money on something you may not even need. :-)
- Kevin
- Kevin
