Help! Broke Sway Bar Mounts
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
My Sway Bar on the driver side broke off from the subframe. It's the two bolts that goes into the subframe where the links is attached. Does anyone know or had this problem before?
Is it safe to drive without the sway bar for now?
Are you talking about the actual mount breaking, or the "U" piece that holds the swaybar to the mount?
If its the actual mount you can buy these to replace them:
http://blainefab.com/swaybrackets.html
You can drive without the swaybar, but it won't drive/behave the same as before.
