Control Arm Relocation brackets
I just pick up a rear end to replace the bent rear end in my 98 bird . the rear axle came with a ta diff cover & control arm relocation brackets can i used them on my stock bird and what is the reason for them?
thanks crazyforgms
thanks crazyforgms
Lower control arm relocation brackets are for lowered cars. They correct a change in suspension geometry resulting from the axle sitting higher in the car after lowering.
I think the description here pretty much covers it:
http://www.umiperformance.com/catalo...roducts_id=117
Oh, and the TA cover is basically just a nicer, aftermarket cover for the rear diff. I believe it has a fill as well as drain plug...not a necessity, but def usable on an otherwise factory car.
