C5 conversion questions
Old Nov 17, 2012 | 11:31 AM
99camaro5.7's Avatar
Question C5 conversion questions
Ok I have a 1999 Z28 camaro I couldn't find all the answers I was looking for so I think I'll just ask them all here. First of all I have the C6 vette wheels on now (17" front 18" rear) I don't know if that will play a factor in any of this or not but thought I'd add it. Is there any place I can just order the whole kit and be done with it or do I need to hunt everything down? I see UMI has a front caliper mount thats a decent price but thats all that comes with it. So if there isn't a complete kit wheres a good place to find c5 calipers front/rear and slotted rotors? And lastly I don't see a caliper mounting kit for the rear so does the c5 calipers and rotors just bolt right up with no modifications? Thank you
Old Nov 17, 2012 | 01:33 PM
Undertow74's Avatar
Ws6store has the complete kit with everything you would need.
Old Nov 17, 2012 | 01:35 PM
Undertow74's Avatar
and the C5 brakes for the front only, there is no need to put that large of a brake on the rear and not to mention if your still maintaining the ABS that would really screw up your braking bias even more.
Old Nov 17, 2012 | 02:11 PM
abs is being deleted in about a month. i want corvette all the way around, so the rears don't need anything but the calipers and rotors though?
Old Nov 17, 2012 | 03:35 PM
do alot of guys run factory fbody calipers in the rear? im not really seeing a kit at all for them
Old Nov 17, 2012 | 11:34 PM
Blackpanther99's Avatar
I also plan on using C5 brakes all around my T/A also. Seen couple of T/A's with those brakes all around and they look really good!
Old Nov 18, 2012 | 05:13 AM
bene's Avatar
Trunion King
It's a moot point to run C5 rear brake calipers as they are virtually the same.
Just run the front C5 brake kit with SS braided lines, semi metallic pads, good DOT 4 brake fluid and you are set.
If you don't like brake dust on your front wheels stick with ceramic pads.
Old Nov 18, 2012 | 07:09 AM
Soo just do the conversion on the front correct? And in the rear just stick with the stock ABS brakes?
Old Nov 18, 2012 | 09:11 AM
ok thanks alot for the help guys, and hope all works out with your t/a blackpanther
Old Nov 18, 2012 | 09:48 AM
Thanks 99Camaro5.7, same for you! Post back in if you get it done it will take me a while to have that process done on mine lol
Old Nov 18, 2012 | 09:53 AM
same here man, probably not until spring lol
Old Nov 19, 2012 | 05:26 AM
UGotBeaT's Avatar
Kore3 makes the kit for front and back....ill be running c6 zo6 brakes all the way around
Old Nov 19, 2012 | 09:50 AM
Wow! is there alot of cutting required to install those rotors?
Old Nov 20, 2012 | 11:00 PM
That's the first I've heard of c6 brakes on an fbody, how much has to be done to get them to work?
Old Nov 21, 2012 | 12:08 PM
UMI Performance's Avatar
The WS6Store sells the complete kit with everything in it and it includes the UMI conversion brackets. http://www.ws6project.com/user_stor/...onversion-kit/
I hope that helps!
Ryan
Old Nov 21, 2012 | 03:51 PM
I hope that helps!
Ryan
Sure does! Thanks Ryan
Old Nov 28, 2012 | 12:18 AM
SnakeStomper's Avatar
Looking at the WS6 pkg as well but have a few lame questions:
1) pkg includes everything you need?
2) is it doable in your garage?
3) any type of cutting/grinding needed?
Old Nov 28, 2012 | 01:02 AM
I should have read the link to ws6's site
Old Nov 28, 2012 | 01:06 AM
I hope that helps!
Ryan
Hi Ryan, that kit says wS6store brackets.
This one says UMI brackets:
http://www.ws6project.com/user_stor/...t-less-rotors/
Old Nov 28, 2012 | 08:13 AM
WS6 Store uses all UMI brackets in their kits, so you will be good.
The install is pretty easy, you do need to cut the spindle but it is simple. The 98-02 brake lines are usually long enough, I recommend to install them and turn the wheels both ways to double check. If you need longer lines buy 97-04 Corvette front lines. Other than that the kits have everything.
I hope that helps!
