Strut tower brace question
Old Nov 17, 2012 | 05:21 PM
Ozzy16's Avatar
Default Strut tower brace question
I just installed my brace by UPI performance on my 2000 trans am, I didint have a tourque wrench on hand since alot of my tools are back home and the installation sheet recommended torquing to 32 foot pounds. Instead I tightened them very snug but not to the point where you couldent tighten the nuts any more and i did not strip the stud or cause any cross threading.. should my studs that are securing the brace be okay? or could they possibly break under pressure while the car is taking sharp corners?
Old Nov 17, 2012 | 06:03 PM
ssgunny's Avatar
32 lbs. isn't a lot. Unless you are going to autox I would not worry about it snapping with the gorilla grip you already seem to have put on it. I suggest buying a cheap TW from Harbor Frieght and get it right.
Old Nov 17, 2012 | 06:36 PM
STFU racing's Avatar
I was under the impression that a strut tower brace doesn't take as harsh a load on our vehicles as you would think. I've never heard of breaking/stripping a bolt out from a STB. I wouldn't worry about it.
Old Nov 17, 2012 | 09:52 PM
ssgunny's Avatar
You are probably right on the load on the shock tower brace. The OP seemed concerned so...
Old Nov 17, 2012 | 11:48 PM
Ozzy16's Avatar
Could some one clarify what specific type of nut this is?? Im guessing its a nylon lock nut but I dont know for sure and my cars stored on the other side of town or I would go check for my self. I know its a 15mm!
Old Nov 18, 2012 | 09:15 AM
ssgunny's Avatar
I just pulled one off and you are correct. It is a flanged nylon lock or nylock nut.
Old Nov 18, 2012 | 12:25 PM
Ozzy16's Avatar
Thanks alot man!!!
