Poly bushings
It is bad until you hit a few bumps then it is not so bad for the rest of the day.
What lube might help from the outside of the bushings to quit these? Seems like it is only the top bushings.
I'm using marine grade grease now.. haven't had a long term test on it, but there's a lot of people that seem to go with this type. Holds up well against the elements.
