Anyone ever used these lowering springs?
I am considering these just to get the car a little bit lower stance. Has anyone on here used them before?
http://www.jegs.com/i/ST-Suspensions...oductId=757252
I just looked up their spring rates (428lbs/in front, 161lbs/in rear) - fronts a little soft for the drop, especially compared to the rear rate. Also the claimed drop seems really weird, I don't know why you would want to drop the rear that much over the front, seems it would give a sagging or reversed rake look.
Id suggest doing a search for lowering springs, there is a reason that certain springs sell so well over others... (ill give you a hint, search "strano")
