Suspension knock, Shock absorbers
Hi, about a year ago i had the lowering kit professionally done at a shop dropping it 1.5" in the front and 1.3" in the rear. Since then i hear a loud and heavy KNOCK in my left rear.. i have taken it to the shop multiple times and they have found nothing. they re-torqued everything, and still the knock persists. I even had them take it for a drive and they couldnt find out what it was, the springs were seated correctly and they even re-seated them just in case.. still a problem. has anyone had this, or have a clue as to what it could possibly be?
i am starting to think it could be a failed shock in that corner, with that being the case, how do i determine a sufficient shock to replace the stock ones. i want it stiff so i dont bottom out on every overpass, but not so stiff that i am riding on a skateboard.. hell no. lol just a tad stiffer than stock.
any help?
any help?
Well I just put a lowering kit on mine and the front passenger there's a knocking when I hit little bumps but he said its probably the sway arm bushing but I doubt that I'm taking Monday to get is check out again
Thank you guys, i will check, so i will get koni's. is there a place that can measure my suspension or take my lowering spring size and tell me the best shock for the car or is it trial and error type of thing
