wiring question
Old Dec 20, 2012 | 05:31 AM
jts98z28's Avatar
Default wiring question
hey, i have no idea where to post this so i put it here, but anyway im trying to find the wiring diagram/pinout or a list of the wires for the brake light switch
any help is greatly appreciated
thanks
Old Dec 20, 2012 | 08:54 AM
Sy99T/A's Avatar
we will be needing the year/make/model info to answer that
Old Dec 20, 2012 | 09:51 AM
jts98z28's Avatar
sorry i forgot to write that, its a 98 camaro z28 A4
Old Dec 20, 2012 | 01:22 PM
Sy99T/A's Avatar
there should be a 2 pin connector and a 4 pin connector for the brake switch on the 2 pin connector terminal "A" is a Orange wire which is battery feed and terminal "B" is a Light Blue wire that is Stoplamp Switch Signal. On the 4 pin connector Terminal "A" is a Pink wire and is Fuse Output-Ignition Terminal "B" is a Dark Green&White it feeds the Shift Interlock Solenoid Terminal "C" is also Pink and is the same as Terminal "A" Fuse Output-Ignition Terminal "D" Purple wire Brake Pedal Output Switch to Torque Converter Clutch
Old Dec 20, 2012 | 02:18 PM
Sy99T/A's Avatar
i can email u the pics or text u the pics, just need a number or address
Old Dec 21, 2012 | 05:48 AM
jts98z28's Avatar
thanks a lot! my email is knorrja91@gmail.com thanks again
Old Dec 28, 2012 | 01:51 PM
Friday13th's Avatar
Originally Posted by Sy99T/A
On the 4 pin connector Terminal "B" is a Dark Green&White it feeds the Shift Interlock Solenoid
Could you tell me where this plugs in? Where is the solenoid located? Do I need to connect it?
