Ground Control
Old Jan 1, 2013 | 03:57 PM
Max Attack's Avatar
Default Ground Control
I have Ground Control ride height adjusters for the front and rear on my 95 Z28. Does any 4th gen springs fit these or do you have to have the Ground Control springs.
Old Jan 1, 2013 | 06:28 PM
HioSSilver's Avatar
Normal 2.5" race springs fit them. I'm not sure of the length you would need though. You could remove yours and check that.
Old Jan 2, 2013 | 02:15 AM
99Bluz28's Avatar
You'll need a 10" length, 2.5" ID coil-over spring up front, and in the rear a 11" or 12" 5.5"ID single pigtail springs in the rear. Hypercoil is the Brand I'd recommend.
Old Jan 2, 2013 | 01:59 PM
Sam Strano's Avatar
LS1TECH Sponsor
It just so happens that Strano Performance Parts is a Hypercoil distributor. If you need springs, give me a yell. They are around $70 or so each depending on rate.
__________________
Old Jan 2, 2013 | 02:10 PM
99Bluz28's Avatar
Wow, I didn't know that myself! Another good reason to buy from Sam!
Last edited by 99Bluz28; Jan 2, 2013 at 03:09 PM. Reason: retracted false statement
Old Jan 2, 2013 | 02:44 PM
Sam Strano's Avatar
LS1TECH Sponsor
Yet another reason you can't just trust everything you see, or don't, on the internet.
And in fact Hypercoil springs are on the site. http://stranoparts.com/searchbymodel...256&ModelID=30 Admittedly, lots of stuff I can do isn't, which is why I ask folks contact me when looking for stuff. I can't possibly get everything I do on there. I did shocks for a LS1tech.com member for his pickup a few months ago, for example. And to be honest if I spent time updating the site with everything possible I'd never be able to actually TALK to anyone and that's more important to me.
__________________
Old Jan 2, 2013 | 03:08 PM
99Bluz28's Avatar
My bad, I apologize and retract my false statement.
Thanks for the correction Sam.
Old Jan 2, 2013 | 07:49 PM
Max Attack's Avatar
Thanks for the help.
