Rear Axle Spring
Old Jan 6, 2013 | 07:10 AM
DaRReLL's Avatar
Default Rear Axle Spring
Is there suppose to be anything under the spring? I can see the isolator spring cushion on top of the spring but mine has nothing where the spring touches the axle. When it is cold I get a squeaking sound from the rear axle area.
Old Jan 6, 2013 | 04:12 PM
buellxb12s's Avatar
No nothing on the bottom. You could put heater house around the bottom coil if you wanted
Old Jan 6, 2013 | 08:33 PM
guy7bmwm83's Avatar
Would adding a little hose affect how the spring sets on the bottom mount
Old Jan 6, 2013 | 08:39 PM
jimmyblue's Avatar
Moderator
Cold squeaking means you need to lube up the rubber
bits - sway bar bushings first, but hit the endlinks, LCA
bushings and the Panhard too.
