help from BMR kmember contorl arm Users
I installed the bmr k-member..upper/lower a-arms. I am trying to get the lower arms reasonably close before alignment. Can someone PLEASE give me some kind of measurement as to the position of the spherical rod end on the lower a-arms. Maybe how many threads you have showing.....anything I may could use to get mine close. I would REALLY apreciate this. Of course I need this info from someone who already has their car aligned. Thanks for any help.
When I installed my front end, I centered all the adjustments and loosely tightened the bolts. Then I mounted the wheels and eye-balled there alignment. Everything looked good except for right wheel toe-in. I adjusted that and took it to the alignment shop and they did a computer alignment. Everything was within specs, they only adjusted the toe-in a little more.
I think your going to have to set it up the best you can. Measuring from one car to the next may have too many variables.
