Panhard bar question.
Old Jan 16, 2013 | 01:19 PM
TAkid23's Avatar
Default Panhard bar question.
Okay I have a 1998 TA, with UMI on car adjustable LCAs
And relocation brackets. I'm looking into UMI on car adjustable Panhard bar. I know one is needed if car is lowered. Mine is not but does has 18 inch C5 Vette rims on the back with a 18 40 275 tire. Since I am running a taller tire wouldn't It be to an advantage with the bar?
Old Jan 18, 2013 | 09:06 PM
Blackpanther99's Avatar
IMO it would be a good thing to do.
Old Jan 19, 2013 | 02:03 AM
01ssreda4's Avatar
I feel like an adjustable PH rod is never a bad idea. It's likely these rears don't sit perfectly centered even when stock.
Old Jan 21, 2013 | 08:32 AM
I believe its a good thing to use also if you have a big wheels on the back of the car to prevent the tire from rubbing. As mentioned above it keeps your rear centered
