Need Help Fixing Sway Bar Mount
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Any suggestion on fixing my frame to mount my sway bar back on? It torn off from the frame and the factory nut was ripped off.
Thanks in advanced!
Thanks in advanced!
Yeah I was thinking of just welding the bracket back on for a permanent fix and since only the bottom hole / nut was ripped off I can still get the bracket in place with the top hole. I used the ADDCO sway bar and they had their own bracket with one hole mount. After my rear bump stop worn out going up and down my drive way was enough to rip off the nut from the frame itself.
